  3. VCAR incorrect path to VCAR
  • Subscribers 133
  • Views 14747
JP Layout
JP Layout over 13 years ago
 I'm working with very little information here since i'm currently working for a stat-up with little to no tech/Cadence support.
When I try to export the cell to the VCAR router, I get a pop up window that reads:
Cannot find Router.
Current path is : vcar
Would you like to select a different path?
What steps would I take to find the vcar path?? Help please.
  • Quek
    Quek over 13 years ago
    Hi JP
    You will also need to intall ICC11241 package if you are using IC5141. Sample cshrc settings:
    setenv CCTHOME $CDS/ICC11241ISR0922/tools/iccraft
    set cctPath = ( $CCTHOME/bin $CCTHOME/lefdef_if/bin $CCTHOME/gds_if/bin )
    Best regards
    Quek
