  3. PWL filename
  • Subscribers 132
  • Views 17705
PWL filename
Tobben24
Tobben24 over 13 years ago
I'm wondering in what folder you are when you specify PWL file name for a ipwlf symbol? Cannot find any info on this in documentation.
    If you specify a "relative" filename (i.e. one not beginning with /) then it will be resolved using spectre's include path. The include path can be setup via Setup->Simulation Files, and if not set, it will look in the netlist directory (which is the working directory for the simulator) - so probably not what you want.
  • Tobben24
    Okay. Can you use enviroment variables there?
    Where?
  • Tobben24
    Where you specify the PWL filename, in Edit Object Properties in schematic editor:)
    That should work. You can't use UNIX env vars in the Include Path in ADE though (I've not re-tested this, but there's a CCR on that).
