  3. Manipulating a single Instance Iterations in Virtuoso
  • Subscribers 129
  • Views 19068
Battosai
Battosai over 13 years ago
I am trying to manipulate the parameters of a single instance of an array (I1<1024:1>). The instances contain a simple RC network and a current source modelling a rather complex circuit. All the instances are connected in series using a bus-notation. Now I need to add a unique delay to every single one of the current sources in order to simulate a propagating signal through this chain of instances.
My idea was to use a skill function to deduce the number of the instance and use it as a multiplier for a constant delay and add it as a parameter of the internal current source. This way all 1024 instances should have a unique delay that is a function of its instance number.
I am fairly new to Skill and seem to be stuck..I managed to access a single instance using ilInst~>name but this returns me the complete name i.e. I1<x>. That's about as far as I came..
Does anyone have experience with this kind of problem or any hints that might help?
    If you have an iterated instance, you can't set different properties on different members of that iterated instance. The whole point is that it's only a single component, but it's expanded to multiple instances when needed. So you can't do what you want - each would have to be drawn separately.
    ilInst is a special variable used for label display; you should not try to use it for anything else.
  • Battosai
    Battosai over 12 years ago
     Hi Andrew
     I take from that that I can't do what I intend to in the schematic editor. To draw all instances and edit them by hand on the other hand seems a bit impractical for so many instances. Isn't there a way to perform the modification i need on a netlist level using netlist procedures in a skill script? Iam looking in to that, but havn't come up with a solution yet (it's my first time attempting something like that and I'm still a bit in the dark)
     Thanks for the input!
    Samuel
  • Battosai
     I have changed my approach a bit. I added the delay parameter i neet to change to the cell using pPar("delay"). In that way the netlister adds the parameter directly to the instance call instead of only the subcircuit. In that way all i need to manipulate is the value of the parameter for every instance. Since it's the first time doing netlist manipulations and the lack of good examples i wrote a custom PrintParameter function that simply overwrites the delay parameter with a fixed value to see if it works:
    (defun MYPrintParameters (formatterId cvId)
        cellview_params = cvId->parameters
        (foreach param cellview_params
            (if param->name == "delay" then
                param->value = "2u"
                cellview_params = nil
            );; if
        );; foreach
        amsPrintParameters(formatterId cvId)
    );; defun
    netId = amsGetNetlister()
    vlog = netId->vlog
    vlog->parametersProc = `MYPrintParameters
    I have made the according changes in the CDF editor (under Simulation Information in the spectre settings under netlistProcedures i added MYPrintParameters) for the cell and saved theMYPrintParameters function in the libInit.il file in the library folder and tried to generate the netlist. Unfortunatly it returns the error:
      *Error* MYPrintParameters: too few arguments (2 expected, 1 given) - (stdobj@0x15ecc170)
    Do I have to add another parameter in the CDF editor or where did I go wrong?
    Thanks for the help,
    Samuel
    Samuel,
    You appear to be creating a netlisting function using AMS netlisting functions (which are for the AMS cell-based netlister), but then using the netlist procedure for spectre (which uses the "nl" netlisting functions). So that's why it's not working.
    Personally I would do this using a schematic pcell, then you don't need to worry about different custom netlist procedures for different simulators - the schematic would work in all ADE netlisters (except AMS cell-based, but would work in AMS OSS/irun flow).
    Here's an example:
    let( (CellLibrary pcellId)
      CellLibrary = "training"
      unless( ddGetObj(CellLibrary)
         error("Couldn't open library %L" CellLibrary)
      pcellId =  pcDefinePCell(
         list( ddGetObj(CellLibrary) "rnsd" "schematic" "schematic" )
         /* Default Parameters
            (ns "1")
         let(( pcCV masterCv instName instId netP netM numInsts)
           /* Get parameter values
           pcCV = pcCellView
           ;; open master cell view
           masterCv = dbOpenCellViewByType( "analogLib" "res" "symbol" nil "r" )
           ;; create the nets
           netP=dbMakeNet(pcCV "PLUS")
           netM=dbMakeNet(pcCV "MINUS")
           ;; create the terminals
           dbCreateTerm(netP "PLUS" "inputOutput")
           dbCreateTerm(netM "MINUS" "inputOutput")
           numInsts=atoi(ns)
           when(numInsts<1 numInsts=1)
           for(inst 1 numInsts
              if(inst==1 then
              else
                 netP=dbMakeNet(pcCV sprintf(nil "net%d" inst-1))
              ) ; if
              if(inst==numInsts then
              else
                 netM=dbMakeNet(pcCV sprintf(nil "net%d" inst))
              ;; create instance
              sprintf(instName "R%d" inst)
              instId = dbCreateInst( pcCV masterCv instName (0:0) "R0" )
              dbCreateProp(instId "r" "string" "pPar(\"r\")/pPar(\"ns\")")
              ;; create instTerms for the instance to connect it up
              dbCreateInstTerm(netP instId dbFindTermByName(masterCv "PLUS"))
              dbCreateInstTerm(netM instId dbFindTermByName(masterCv "MINUS"))
           ) ; for
           dbClose( masterCv )
           ;; Always return true
           t
         ) ; ** let **
      ; not sure if below is really necessary
      dbSave(pcellId)
      dbClose( pcellId )
    ) ; ** let **
  • Battosai
     Hi Andrew
    I do like the approach using a schematic PCell.. It's quite elegant. I have tried it out and it seems to do the trick quite well. I will have to remember this approach for future projects!
    Thank you very much for your valuable help!
    Samuel
