  3. licence requirment for Analog Autoplacer
  • Subscribers 133
  • Views 15260
waseemarshad
waseemarshad over 13 years ago
When I run autoplacement in virtuoso VLS-GXL I get following errors
Analog Autoplacer unable to checkout license/tokens sufficient to run. Check that you have sufficient licenses and are in VLS-GXL
what could be the solution.
Regards
waseem
  • wschwab
    wschwab over 13 years ago
    Hi Waseem,
    a VLS-GXL license has 12 tokens.
    For running Virtuoso you need 4 token. The Analog Auto Placer requires additional 8 token. When starting the Auto Placer you must be sure that these 8 tokens are available. If you run 2 Virtuoso sessions then there are only 4 tokens left. Exit one Virtuoso session and then start the Auto Placer.
    Regards
    Werner
