  3. License issue while using plot command in an ocean script...
  • Subscribers 132
  • Views 18242
License issue while using plot command in an ocean script in cadence 6.1.5
NRkey99
NRkey99 over 13 years ago
when I am using plot() command in my ocean script in cadence version 6.1.5 it is checking for ADE_L/ADE_XL license,but when I am using the same command in cadence version 5.1.4, it is showing no such message & is excuting the command. Can anyone suggest what the problem might be?
    I don't know which licenses you have, but presumably it is working but just giving some warnings?
    If so, adding:
    envSetVal("wavescan.application" "VIVALicenseCheckoutOrder" 'string "ADE,VIVA")  ; default is VIVA,ADE
    envSetVal("license" "ADELicenseCheckoutOrder"  'string "GXL,L,XL") ; default is L,XL,GXL
    might help. I'm assuming here you have ADE GXL licenses and not the others. The idea is that these control the default order it checks for licenses - and you can tune that to the licenses you actually have.
    Seeing the message you're getting might help me to give a better answer, along with knowledge of what ADE licenses you actually have.
  • NRkey99
    Thanks for your reply.
    First of all, I don't have any ADE license (I have only Virtuoso_Schematic,111 & Spectre licences).
    But my question is how am I able to run this same command in 5.1.4 version ?
    Manually I am able to plot all the results (in 6.1.5 version) but it is a big simulation & I need to automate few things, that's why the script.
    In 6.1.5 it gives the following warnings when I try to access spectre results through any ocean commands :
    ocean> *WARNING* (icLic-3) Could not get license Analog_Design_Environment_L
    *WARNING* (icLic-21) License Analog_Design_Environment_L ("95200") is not available to run ADE-L.
    Trying to check out the license Analog_Design_Environment_XL ("95210") instead.
    *WARNING* (icLic-3) Could not get license Analog_Design_Environment_XL
    *WARNING* (icLic-21) License Analog_Design_Environment_XL ("95210") is not available to run ADE-L.
    Trying to check out the license Analog_Design_Environment_GXL ("95220") instead.
    *WARNING* (icLic-4) Could not get token capability Analog_Design_Environment_GXL
    *WARNING* (icLic-22) License Analog_Design_Environment_GXL ("95220") is not available to run ADE-L.
    *WARNING* feature Analog_Design_Environment_L: Licensing OK.
    *WARNING* (icLic-21) License Analog_Design_Environment_XL ("95210") is not available to run ADE-XL.
    *WARNING* (icLic-22) License Analog_Design_Environment_GXL ("95220") is not available to run ADE-XL.
    *WARNING* feature Analog_Design_Environment_XL: Licensing OK.
    *WARNING* (icLic-22) License Analog_Design_Environment_GXL ("95220") is not available to run ADE-GXL.
    ERROR (ADE-6015): The  check-out of the Artist simulation environment feature ("Analog_Design_Environment_L") failed. For proper check-out:
            [1] Check your license file.
            [2] Ask a current user of the feature to exit the Artist simulation environment.
    nil
    *WARNING* feature Analog_Design_Environment_GXL:
    Any suggestion is hearfully welcome
    Regards
    I don't know how you ever got it to work in the past. OCEAN has always required an ADE license - it's essentially part of ADE.
    Historically wavescan could be run with just a spectre license (this was mainly intended for MDL mode), but in IC615 ViVA always requires either a ViVA-XL license or an ADE license. So I've no idea how you've managed to plot manually in IC615, let alone how you plotted from OCEAN in IC5141 (maybe you're using a really old IC5141 build that had a loophole in the license checking?)
