  3. Simulations stalling in ADEXL: Can't initialize LBS
  • Subscribers 132
  • Views 2190
srftech
srftech over 13 years ago
 So we have installed cadence onto a new system, setup our project and have been able to run sims using ADE just fine.  In setting up ADEXL to run corners and parameter sweeps, we have encountered the following error:
ERROR (ADEXL-1932): Could not initialize LBS using the SKILL command (adpiInitLbs).  Error: lbpsGetComponentHandle: Failure starting command: qstt
Verify that you have initialized your enviroment to use SGE software and that executable can be found using that enviroment.  LBS will not be available for job distribution hiCaughtControlC
I am beginning to read about starting SGE and the associated env setup needed, but I am still novice at CAD administration, so hoping someone else will have an easy solution...sooner than the 24hr it may take me to figure it out. ;)
Thanks!
    I would suggest contacting customer support over this. The likely reason for your problem is that you don't have the SGE software in your path (assuming you actually intended to use SGE) - and so it can't find the qstat command (which is one of the SGE commands).
    By the way, I would first ensure that you can submit jobs with SGE from the command line before starting to try to get it working with ADE L/XL.
    By the way, it would probably be easier to help if you described what you'd actually done to set this up - i..e what environment variables, precisely what options you'd picked in ADE XL and so on.
    Kind Regards,
