  3. problem of running IC5141 in Centos 6.3
  • Replies 11
  • Subscribers 133
  • Views 21383
neuro
neuro over 13 years ago
I have installed IC5141 in CENTOS 6.3, but there are some problems in running IC5141. The startup speed of IC5141 is very slow. and when I click the menu "library manager...", IC5141 hangs.
This is the log of CDS.
COPYRIGHT © 1992-2008  CADENCE DESIGN SYSTEMS INC.  ALL RIGHTS RESERVED.
          © 1992-2008  UNIX SYSTEMS Laboratories INC.,
                         Reproduced with permission.
This Cadence Design Systems program and online documentation are
proprietary/confidential information and may be disclosed/used only
as authorized in a license agreement controlling such use and disclosure.
          RESTRICTED RIGHTS NOTICE (SHORT FORM)
Use/reproduction/disclosure is subject to restriction
set forth at FAR 1252.227-19 or its equivalent.
Program:                @(#)$CDS: icfb.exe version 5.1.0 10/28/2008 10:23 (cicln03) $
Sub version:            sub-version 5.10.41_USR6.127.29 (32-bit addresses)
Loading PRshare.cxt
Loading layerProc.cxt
Loading ams.cxt
Loading acv.cxt
Loading auCore.cxt
Loading schView.cxt
Loading seismic.cxt
Loading seismic.cxt
 *WARNING* Unable to start up library manager (libManager.exe) after 60 tries. There maybe an access or network problem. Start the library manager from an Unix Shell window to test the accessibility. Variable ddsvMPSTimeOut (60) can be set to increase or decrease the number of attempts. cdsServIpc: ipcIsAliveProcess connection timeout (host:neuro)
i have disabled selinux and checked on protocols in Firewall configuration and reboot the system but no improvement.
 Any suggessions please??
    First of all, this is an unsupported (i.e. untested) OS. This solution suggests increasing the timeout, but I suspect that won't help. What do you have in /etc/hosts ?
  • neuro
    Thanks a lot for quick reply. Oh i did not that this is untested. just downloaded latest version and installed(feeling stupid now)
    here is my /etc/hosts
    127.0.0.1    localhost.localdomain localhost4 localhost4.localdomain4
    ::1         localhost localhost.localdomain localhost6 localhost6.localdomain6
    133.11.58.5 vdec-cad1
    133.11.58.6 vdec-cad2
    133.11.58.7 vdec-cad3
    Not sure the reason - nothing jumps out at me. Probably best to talk to customer support (although I would check with a supported OS; for IC5141 that's RHEL4 (RHEL3 should be OK too) - follow the link from Support & Training at the top of the page to Computing Platforms - you'll get here.).
  • neuro
    Thanks again. I will try with a compatible version  first.
    It just wasted  me a full day....
  • neuro
    someone told me that he installed IC5141 in centos 5.3. But i can see only Centos 5.8 available in the public mirror. All ohter version of 5 are depreciated. Should i try with 5.8, what you think.
    Thank You
    That's not a supported OS either. It may well work, but I couldn't comment as to the likelihood.
  • neuro
     Ahh...ok i understand
  • Kaou
    Kaou over 12 years ago
    I am having a similar problem on a IC6.1.6 installation, additionally, I'll get an error about cdsServIpc connection timed out, and that the system couldn't find a 64bit version of cdsServIpc. I've seen posts on other forums suggesting that this error is simply a misconfigured network on behalf of the host, and not an issue with Cadence. Can anyone confirm that there shouldn't be a 64bit cdsServIpc, because when I try to run the 32bit version individually, it always ends in a segmentation fault.
    The fact that cdsServIpc crashes when you invoke it with no arguments is a known issue which is planned to be fixed in IC617 (CCR 1117755). However, in practice that's not going to be the real issue here because cdsServIpc is never called with no arguments. If you run (say) "cdsServIpc -version" it should work OK.
    There is no 64 bit version of cdsServIpc - there doesn't need to be because it would never need the additional memory capacity.
    If you are getting errors about connection timeouts, I suggest you contact customer support with details of the precise error message and what you were doing at the time.
    Kind Regards,
  • Kaou
    IC613 launches without problem, so the network is responding. Do you know if there were any changes made to how one should setup the license between IC613 and IC616? Also, where would one go to change the variable, ddsvMPSTimeOut ,is this something that should be done in our environment setup (ie. setenv or export)?
