  3. Bits as Inputs
  • Subscribers 132
  • Views 18860
Bits as Inputs
girishmtech
girishmtech over 13 years ago
Can anyone tell me how do I give bits as input ie 100001010111.
Is der ny ways..
Help me if u know abt vector file
pls do the needful
  • girishmtech
    Is der ny ways..
    pls do the needful
  • girishmtech
    Is der ny ways..
    Or thru Vector file how do I give the inputs???
    pls do the needful
  • girishmtech
    Question is based on Cadence Virtuoso.
    I would like to know on how do i give bits stream as inputs.
    I am finding it difficult on how dI proceed.
    Pls do the needful.
    Thanks for your feedback
  • girishmtech
    Hi pls do reply I am in great need of help.
    I heard one way of inputing the random its as inputs is thru Vector File... can anyone pls help me in performing dis...??? It says I need to add a syntax in the netlist file of cadence virtuoso and I dono on how to add it.. pls do the needful
    You are going exactly the right way about irritating the hell out of everyone on these forums. I don't like to be quite so blunt, but if you'd read the forum guidelines you'd see that you've:
    1. Posted the same question four different places - this post plus /forums/p/24744/1319268.aspx#1319268 /forums/p/24858/1319232.aspx#1319232 and /forums/p/24801/1319231.aspx#1319231 - two of which are appends to completely unrelated topics.
    2. Used poor spelling and (presumably) messaging short hand. I've no idea what "Is der ny ways" means - maybe you meant to write "Are there any ways?"
    3. Not given any information about what tool you're using - e.g. what simulator (assuming it is even a simulator question).
    4. Be rather pushy about getting an answer - this is a community forum manned by volunteers - both from within Cadence and amongst the user base.
    So please "do the needful", and read the forum guidelines, and post a properly formed question with sufficient information that somebody can answer it.
    In the meantime I'll clean up the mess and merge all your four appends into this one.
    Kindest Regards,
