  3. back annotation of paracitics into schematic
  • Subscribers 129
  • Views 13798
Zitty
Zitty over 12 years ago
Hey there,
I´m trying to hunt down paracitics within my design.
I already did a qrc extraction of my layout and got an av_extracted. Then I performed a simulation on this file by choosing it from the config file.
I read that I can create an av_analog_extracted that can be used to back annotate the paracitics to the layout.
To do so I followed the description in this post (www.cadence.com/.../22931.aspx).
My first question on this is: What´s the difference between the av_extracted and the av_analog_extracted?
My dc-sim I´m starting out of the config-file of my testbench always exits with an error. The exracted paracitics can not be found.
How should I setup theese tests? I also hat a look on the parasim document but I did not get what the problem could be.
  • Zitty
     ok at least the error was solved. I insterted the components as model during qrc extraction.
