  3. nmos 3-terminal device vs nmos 4-terminal device
  • Views 15830
arundevnkumar
arundevnkumar over 13 years ago
i had drawn the schemaic for nand gate using 3-terminal nmos &pmos.
i had drawn the automatic layout from the schematic.
when i do the DRC ,there is no error.
but if i do the lvs it shows some mismatches.
    Do you have a question? Whilst I'm sure everyone is interested in what you've been working on, I presume you've got some issue that you want some assistance with. I suggest you read the forum guidelines and ensure you provide sufficient information for anyone to be able to help you.
    Kind Regards,
  • DharaP
    DharaP over 10 years ago
    check out the pins like vdd,gnd, in and out. all are at proper place or not
