  3. umc 180 nm LVS with Calibre
  • Subscribers 133
  • Views 17407
soathana
soathana over 13 years ago
First I must say I must not sure if this should be asked here or Mentor's forums, anyways because I have used this forum before I will fire it up here...
While using Virtuoso for custom layout on UMC 180 and trying LVS check with Calibre I have a problem with ports.
In theory that should be easy as defining the layer of the pin same as metal-pin in my case that i am using Metal1 as "ME1 pin" and the text as "M1_CAD TEXT" problem is that it does not work and i get missing ports
any ideas/suggestions are greatly apprecieated.
cheers,
Sotiris
  • Quek
    Quek over 13 years ago
    Hi Sotiris
    This question should be posted in Mentor Graphic's forum. You can check the following:
    a. Wrong gds number/type when reading in labels
    b. Is "TEXTTYPE" used when reading in the labels?
    c. Have the text layers been delared as ports using PORT LAYER TEXT cmd?
    Best regards
    Quek
