  3. Resizing multiple objects in Virtuoso
  • Subscribers 132
  • Views 18319
Agustino
Agustino over 13 years ago
Hi all,
I have many objects, for instance, 5 rectangle. Assuming I want to change all of them to the same width. I did try to select all of them, open properties window, and then set the width. However, it applied new width to the first rectangle only and leave the others unchanged.
I am wondering if there is any quick method to elaborate it ?
Thank you so much.
    Did you hit the "common" button?
  • Agustino
    Thank you, Andrew! It works fine now. Yesterday, I did select all objects, then apply changes to a couple of first objects, and then I check "common" button. I guess it's the reason.
