  3. PEX setup
  • Subscribers 132
  • Views 16427
PEX setup
Arshya
Arshya over 13 years ago
I am using PEX for extraction of my layout in AMS0.35 OPTO. When running PEX I get an error when viewing saying "Incorrect MASK SVDB DIRECTORY options for this funtion". I cannot see the extracted view, and apparently, I cannot get correct extraction. Does anyone know what the SVDB directory is and where I should find it?
    Which extraction tool are you using? I suspect from the terminology that it might be Mentor's Calibre XRC, but please clarify.
  • Arshya
    Thanks for your response Andrew. You are right. My extraction tool is Mentor's Calibre XRC.
    In that case you'd probably be best asking this on a Mentor Graphics forum. You may well be able to get somebody who can help you out here, but I'd say your chances were higher on an MGC forum.
    Kind Regards,
