  3. Positioning the instances in Layout editor by using SKI...
  • Replies 34
  • Views 39539
Positioning the instances in Layout editor by using SKILL
RFStuff
RFStuff over 13 years ago
 Dear All,
I am trying to place copies of an instance/object ( say a simple via ) with 'x' distance separation in X-direction.
Is there any in-built feature already available in IC5141 ?
Otherwise, is there any solution ( SKILL script) already posted in the forum ? I searched but couldn't find so.
The code needs three functions:
1) Find the cordianate of the OBJECT/INSTANCE ( this I have already found in the Forum)
2) Copy the object. For this what is the SKILL function ?
3) Paste the desired distance separation ( For palcing wht is the simple SKILL function)
Couls anybody please tell regarding this.
Kind Regards,
    I didn't search to see if there was any code that does what  you want, but it's trivial to write.
    If you have the pitch in a variable dx, and the number of copies in numX, and the instance in instId, and cellView in cvId :
    for(x 1 numX
      dbCopyFig(instId cvId list(x*dx:0 "R0" 1))
    So not hard...
  • RFStuff
     Dear Andrew,
    Thanks a lot.
    The dbCopyFig(), copy the figure at the relative offset with respect to the Lower Left corner of the bBox of the original object.
    Is it possible to place/copy the object to a given arbitrary coordinate.
    Also is it possible to make the relative movemt with respect to some other coordinate of the bBox.
    Of courseone can write a script and do the manipulation to achieve the same. However I believe there may be way to do it by a single command.
    Kind Regards,
    To copy to an absolute coordinate, you need to produce a concatenated transformation which moves back to the origin, then to the location you want. So for example, if you want to copy the lowerLeft of your object to a location xy, you'd do:
    dbCopyFig(instId cvId dbConcatTransform(list(-xCoord(lowerLeft(instId~>bBox)):-yCoord(lowerLeft(instId~>bBox)) "R0" 1) list(xy "R0" 1)))
    I don't really understand your second question, since a relative movement doesn't matter which coordinate it is with respect to - all coordinates in the bBox will move by the same relative amount.  Maybe you're talking about an absolute move - in which case something like my suggestion above would make sense - you just compute the first transformation using a different coordinate on the shape (such as the upperRight rather than the lowerLeft).
  • RFStuff
     Dear Andrew,
    Thanks a lot.
    Yes, what you have mentioned, I want exactly that.
    One can copy and place by using dbCopyFig(),
    I actullay want something as follow:-
               I have a PATH running in MEx
              I want to run PATHs of different metal  undeneath/over it. The PATH may be of a) same width or b) different width
             For Same width:-
             obj=car(geGetSelSet())
              newPath=dbCopyFig(obj obj->cellView list(0:0 "R0" ))
              newPath~>layerName=sprintf(nil "ME%d",val)
           It works fine.
             For different widh:-
             I think oneway is to change the bBox property  of the copied PATH.
            With this line of thought I did as follows:-
             bBoxNew=list(a:b c:d) % please note a,b,c,d are floating point desired co-ordinates
              newPath~>bBox=bBoxNew.
              However the above DID NOT WORK.
            Could you please tell what is the issue.
    Kind Regards,
    You cannot change the bBox of a path (or pathSeg) as it is a derived parameter. You can change the ~>points to alter the points in the path, or the ~>width to change the width.
  • RFStuff
    O I forgot, that PATH has width property and one can assign new width to the existing width property.
    newPath~>width=newWidth.
    Indeed worked.
    But why bBox is not working.
    Also I want to run a prallael path on both side of the MAIN path ( the PATH has multiple bends) . What should be done. Basically I want to make a shiled around the PATH
    As I said, changing the bBox makes no sense for a path, because it is computed from the width/points of the shape, and so is a derived parameter rather than something that defines the shape.
    If you want to offset from an existing path, you would probably be better off using rodCreatePath to do it. I suggest you read the documentation for this function (as it is quite powerful and has a lot of options, and there's no point me repeating the documentation in the forum when you can read the details yourself). This would allow you to create a path separated from the original path, which follows the bends of the original path correctly.
  • RFStuff
     Dear Andrew,
    Thanks a lot  for your reply.
    I actaully had posted my previous query before I saw your post so did not get the fact that bBox is a derived property for PATH.
    I will see rodCreatePath() in the ROD document.
    Again thans a lot.
    Kind Regards,
  • RFStuff
    Dear Andrew,
    I used rodCreatpath().
     I drew the shielded path by doing
    SignalPath=rodCreatePath(.....
            ) ;end rodCreatePath
     but SignalPath~>points is giving "nil" though SignalPath is showing ROD object ID
    Could you please tell why it is showing like this.
    What canbe done to access  the attributes of the rodObject ?
    Kind Regards,
    Because the rod object is a container object which contains some additional information and handles on top of the database id. So you'd use:
    rodId~>dbId~>points
    to get the point list.
