  3. Virtuoso - Wire Bus Connectivity Issue
  • Subscribers 129
  • Views 8455
sohaiba
sohaiba over 12 years ago
I am facing this issue regarding how to connect the wire bus connection to the output connectors. If you look at the attached image below I have clearly named each bus bit to its output but I am still facing error.
Bus_output
The screenshot image displaying the error is below
Error Prompt
 Any help would be appreciated.
Regards
    The key is labelling the whole bus. I also label the taps as they exit the bus - I didn't explore too much what does and doesn't work, but the picture I've uploaded works correctly - so hopefully that will allow you to do what you want (the inverter on the left end was just a means of me creating a 6 bit bus as it is an iterated instance; it shouldn't make any difference that you have a symbol with a bus pin).
  • sohaiba
     yes thank you. it works.I didn't tag the bus wire.
