  3. Ruler (bind-key 'k') not functioning as desired
  • Subscribers 132
  • Views 12082
RFStuff
RFStuff over 13 years ago
Dear All,
It may be a silly question. But the issue is creating a lot of problem for me.
I want to draw the ruler from 'x' point to 'y' point orthogonal.The ruler should begin at 'x' and end exactly at 'y'
I draw the ruler like:-
                           1) Press button 'k'
                           2) Zoom in   ( hiZoomIn() ) to the desired point ( x) location by clicking Right Mouse Botton ( for getting the exacr point fine ZOOM-IN)
                           3) Then  press Left Mouse botton at point 'x'
                          4) Then I press Zoom-Out in the Tool Bar (Course Zoom-Out)
                         5)   Zoom in   ( hiZoomIn() ) to the desired point ( x) location by clicking Right Mouse Botton ( for getting the exacr point fine ZOOM-IN)
                         6) Then  pressRight Mouse botton at point 'y'
This works fine for me. But at times I don't know what happens, while doing zoom-in using Mouse ( when I press Right Mouse botton) the Ruler gets marked.
Then I have to close icfb ( IC5141) and restart it. Then things work fine.
Could anybody please tell why it is happening so  and what should be done to avoid it.
Kind Regads,
  • RFStuff
    Just to add to it:-
    While this issue happens "
    In CIW I get warning as:-
     *WARNING* Cancelling function, exceeds nestability limit of 5.
    What it means ?? What is its cause ?
  • theopaone
    theopaone over 13 years ago
     The warning is the key. You have more than 5 enterfunctions working at the same time and when you enter the zoom, you exceed the command stack. You are probably inside of an editing command such as move or stretch as well as the editing commands. Type ^C (ctrl C) a couple of times to make sure you have exited the functions, this may save you from having to restart Virtuoso.
    If this is something you do often, you may want to create a SKILL program that prompts you for the two zoom points, lets you enter the first point for the ruler, then zooms back out and prompts you for the next zoom points and then the last point for the ruler. Then it draws the ruler.
    If you wre using IC615, there is a built in snapping ruler. It snaps to edges/endpoints without having to zoom in.
    Ted
    Rather than using control-c you can just hit escape a few times to cancel out of nested functions. If you have multiple editor windows open within the same icfb, make sure you escape nested commands in all the windows - the nest limit is global, not per-window (if my recollection is correct). I think there was an issue in older versions where you could end up with uncancellable nested commands if you closed a window in the middle of a command (not sure if that was resolved by the version you're using)
    Finally you can increase the nest limit in options->user preferences in the CIW.
