  3. Customized Schematic Generation Using Skill
  • Subscribers 133
  • Views 14670
T Opperman
T Opperman over 13 years ago
I need to think of ways to generate top level circuit schematics using skill. I thought about using verilogIn, but I later realized that it does not provide me with much flexibility, and it does not allow me to map specific libraries to specific module/cell instances. What also happens is that I have symbols form different libraries with different pin lists that has the same module/cell names.
So as I looked through the sch* functions in skill, I was unable to identify a straightforward method to instance a symbol in a schematic, and specify labeled wires to be connected its pins. It doesn't have to be routed. I suppose one can go about opening each symbol to obtain its pin locations/labels, but it seems a bit tedious and prone to bugs. Does anyone know of any higher level functions to do this?
Tjaart
  • Quek
    Quek over 13 years ago
    Hi Tjaart
    How about simply querying each symbol to get the terminal/pin info?
    symbolID~>master~>terminals~>name
    Hope that I am not misunderstanding your question. Or are you looking for schSymbolToPinList function?
    schSymbolToPinList("myLib" "myCell" "symbol")
    Best regards
    Quek
