  3. spectre error
  • Subscribers 133
  • Views 19146
spectre error
siva123
siva123 over 13 years ago
 hi sir,
iam simulating  on common source amplifier by using spectre simulator.I given source signal as a vpulse it taken in my analog lib.
i given all the Vpulse waveforms parameters (i.e Ac magnitude,ac phase,Dc voltage ,voltage1,voltage2, time period,rise time,fall time ,delay time & pulse width) then simulation run throug netelist &run button of spectre tool (ADE L)
BUT IT SHOWS ERROR
i.e
Error found by spectre during hierarchy flattening.
ERROR (CMI-2194): V1: Waveform type must be specified if any waveform parameters are given.
Time for EDB Visiting: CPU = 999 us, elapsed = 885.963 us.
Time accumulated: CPU = 1.71174 s, elapsed = 2.29704 s.
Peak resident memory used = 58.2 Mbytes.
spectre terminated prematurely due to fatal error.
my aim is to find out DC gain,Unity-gain frequency & slew rate
venkata siva
  • Quek
    Quek over 13 years ago
    Hi venkata siva
    Would you please post the line in the spectre netlist for "V1"? E.g.
    V1 (net05 OUT) vsource dc=0 type=dc
    V2 (IN 0) vsource dc=VDD/2 type=sine freq=1M ampl=50.0m mag=1
    Quek
  • siva123
    hi Quek
    These are the v0 & v1 values given by me
    V0 (vdd! 0) vsource dc=3.3 type=dc
    V1 (Vin 0) vsource dc=Vindc mag=1 phase=0 type=sine delay=1p ampl=2.5
    thanks,
    venkata siva
    My guess is that you don't have $CDS_Netlisting_Mode set. You should do:
    setenv CDS_Netlisting_Mode Analog
    if using csh, or if using bash/ksh it would be:
    export CDS_Netlisting_Mode=Analog
    before starting virtuoso/icfb. You may need to do a Simulation->Netlist->Recreate in ADE.
  • siva123
     hi Andrew
     thanks it s run
    thanks,
    venkatasiva
