  3. Returning multiple variables in SKILL function
  • Replies 11
  • Subscribers 131
  • Views 20466
RFStuff
RFStuff over 12 years ago
 Dear All,
I want to a skill function that can return multiple values.
Like: (a,b)=skillfunction(x,y,z....)
Could anybody please tell how it can be done.
Kind Regards,
  • skillUser
    skillUser over 12 years ago
    Looks like you might be used to Perl, but one way to do this in SKILL is to return a list of values, but you would have to assign them to variables outside of the function call in a more manual way.  Here's a brief outline:
      procedure(skillfunction(x y z)
        let( (ret1 ret2)
        ;; do some function on these parameters
        ret1 = x + 2*y
        ret2 = y - z
        ;; this next line is the return value of the function
        list(ret1 ret2)
        ); let
      ); procedure
      retlist = skillfunction(10 20 5)
      a = car(retlist)
      b = cadr(retlist)
    Something like that. Function arguments are separated by whitespace.  If you have more than a couple of variables then you might consider a more general approach, for example using a table structure for storage in named slots.
    Hopefully this is helpful to you.
    Lawrence.
    Returning multiple values as a list is a clean way to do this, but you can also use the destructuringBind function (new in IC615) to destructure the list contents and assign to variables (local to the scope of the destructuringBind function). This example uses the function that Lawrence wrote above to illustrate this:
    destructuringBind((a b) skillfunction(10 20 5)
      printf("a=%L b=%L\n" a b)
    You can use this with other interesting list structures - for example, imagine that you have an instance id from the database - you can do:
    area=destructuringBind(((llx lly) (urx ury)) instId~>bBox
      ; compute the area of the bBox
      (urx-llx)*(ury-lly)
    Cool, eh? (OK, so I'm easily impressed)
  • kb how
    kb how over 12 years ago
    Interesting ...!
    Thanks for the sharing.
  • RFStuff
     Dear  Lawrence & Andrew,
    Thanks a lot.
    Andrew: It is really nice. But is this feature available in IC5141.
    Kind Regards,
    In IC5141 you could use the following for the simple (non-nested list) case:
     (defmacro CCFsimpleMultiAssign (listOfVars listValue @rest body)
      `(apply (lambda ,listOfVars ,@body) ,listValue)
    and then use CCFsimpleMultiAssign instead of destructuringBind in my first example. This won't work for the second bBox example - it would need a more complex macro (I threw the above together pretty quickly).
  • RFStuff
    Dear Andrew,
    Thanks a lot.
    Kind Regards,
  • theopaone
    theopaone over 12 years ago
     destructuringBind is wicked magic that should be studied in IC615. It is very useful, especially since you can return keyed values, optional values and @rest values.
    Before IC615, you could return the values as a disembodied property list (DPL). It is a list of key value pairs that begins with a nil:
    list( nil key1 "value1" key2 2.0 key3 list( "Value" "number" 3 ) )
    myDPL = callingMyFunction(....)
    myDPL->key1 => "value1"
    myDPL->key2 => 2.0
    myDPL->key3 => list("Value" "number" 3)
     Ted
  • RFStuff
    Dear Ted,
    Thanks a lot.
    Kind Regards,
  • theopaone
     You know you are in trouble if you dream in SKILL.
     In my last post, I made an error and realized it last night. The key values in a DPL must be symbols. In the example, they are variables and the code may fail but will definately not work the way it was written. The DPL should be written as:
     list( nil 'key1 "value1" 'key2 2.0 'key3 list( "Value" "number" 3 ) )
     The keys must be quoted to be symbols.
    Ted
  • B Bruekers
    B Bruekers over 9 years ago
    I've been using the destructuringBind function and I've noticed that SKILL Lint does not understand the destructuringBind function correctly?
    code:
    bbox = list( '(0 0) '(1 2))
    area= destructuringBind(((llx lly) (urx ury)) bbox (urx-llx)*(ury-lly))
    First it complains that the llx, lly, urx and ury are defined globally. So after putting then in the let() I get the following errors:
    ERROR (CHK3): C:/Cadence/skill/test.il, line 455 (test) : Bad argument ( must be a symbol) : (llx lly)
    ERROR (CHK3): C:/Cadence/skill/test.il, line 455 (test) : Bad argument ( must be a symbol) : (urx ury)
    Do you have any idea if SKILL Lint is correct in these cases? Or should I just ignore this error?
    Bram
