  3. customize viva strip
  • Views 18511
xhdong
xhdong over 13 years ago
Dear all,
   How can I customize viva to set:
1.  "split trip" while not "combined trip"
2.  plot to new strip by default
Thanks!
    Which version of the tools are you using (this is important to know) - Help->About in the CIW will tell you the subversion.
  • xhdong
    cadence IC6.1.5.500.132. Thanks!
    I don't know what you mean by '"split trip" while not "combined trip"' - it doesn't make sense to me (even assuming that you meant "strip" instead of "trip").
    For the second question, this is  Graph->Plot to new strip. You can set this as your default by putting this in your .cdsinit:
    envSetVal("viva.rectGraph" "stripChartOn" 'string "true")
    or this in your .cdsenv :
    viva.rectGraph stripChartOn string "true"
  • xhdong
    Andrew,
      Thank you very much! It does be what I wanted.
    For the first question, yes, it should be "strip". I means I want to choose "split current strip" by default while not "combine all analog traces".
    When I set .cdsenv as you said, it also works. The problem is gone.
    Thanks!
