  3. How to plot an histogram using ocean script? (monte carlo...
  • Subscribers 132
  • Views 15881
How to plot an histogram using ocean script? (monte carlo problem)
Ricardo Alves
Ricardo Alves over 13 years ago
Hi all,
I am new using Ocean script and i am having a problem.
I want to do an histogram with the average value of a comparator output (voltage).
However I couldn´t get it yet.
The code i am trying to implement is the following:
ocnWaveformTool( 'wavescan )
simulator( 'spectre )
design(     "/home/user22/simulation/comparator/spectre/schematic/netlist/netlist")
resultsDir( "/home/user22/simulation/comparator/spectre/schematic" )
modelFile(
    '("/opt/ic_tools/pdk/umc130_b06_pb/umc13mmrf/../Models/Spectre/l130e-rf-v171-control.scs" "")
    '("/opt/ic_tools/pdk/umc130_b06_pb/umc13mmrf/../Models/Spectre/L130E_MM_TRIPLEWELL_MAIN_V151.lib.scs" "")
    '("/opt/ic_tools/pdk/umc130_b06_pb/umc13mmrf/../Models/Spectre/l_cr20k_rfvil_V021.lib.scs" "typ")
    '("/opt/ic_tools/pdk/umc130_b06_pb/umc13mmrf/../Models/Spectre/l_nwcr20k_rfvil_V021.lib.scs" "typ")
    '("/opt/ic_tools/pdk/umc130_b06_pb/umc13mmrf/../Models/Spectre/l_sy20k_rfvil_V021.lib.scs" "typ")
    '("/opt/ic_tools/pdk/umc130_b06_pb/umc13mmrf/../Models/Spectre/l_nwsy20k_rfvil_V021.lib.scs" "typ")
    '("/home/user22/CADENCE/UMC130_B06_PB/Monte_Carlo_libs/L130E_statistical_m.scs" "")
    '("/opt/ic_tools/pdk/umc130_b06_pb/umc13mmrf/../Models/Spectre/l_sy20kct_rfvil_V021.lib.scs" "typ")
    '("/opt/ic_tools/pdk/umc130_b06_pb/umc13mmrf/../Models/Spectre/l_nwsy20kct_rfvil_V021.lib.scs" "typ")
    '("/opt/ic_tools/pdk/umc130_b06_pb/umc13mmrf/../Models/Spectre/l_sqsk_rfvil_V021.lib.scs" "typ")
    '("/opt/ic_tools/pdk/umc130_b06_pb/umc13mmrf/../Models/Spectre/l_nwsqsk_rfvil_V021.lib.scs" "typ")
    '("/home/user22/CADENCE/UMC130_B06_PB/Monte_Carlo_libs/L130E_HS12_V231_ma.lib.scs" "tt")
analysis('tran ?stop "170u"  )
save( 'v "/out" )
temp( 27 )
monteCarlo( ?numIters "2" ?startIter "1"
    ?analysisVariation 'mismatch ?sweptParam "None"
    ?sweptParamVals "27" ?saveData t
    ?nomRun "yes" ?append nil
    ?saveProcessParams t
monteRun()
selectResult('tran)
monteSelectResults()
specLimits ("bw_27" ?upper 15E+06 ?lower 5E+06)
monteExpr( "bw_27" 'average(clip(v("/out" ?result 'tran) 0 85u)))
histogram( "bw_27" ?type 'standard ?numBins '2 ?density 't)
The error is shown bellow:
simulation completed successfully.
 reading simulation data...
       ...successful.
 Monte Carlo Simulation completed successfully...
 Statistical Analysis Parameters and Spec Limits:
         Parameter        Lower        Upper
     noExprs_27       -1e+36       1e+36
 *Error* eval: not a function - "bw_27"
 *Error* load: error while loading file - "monteCarlo.ocn"
  Can anyone help me please?
Regards
Ricardo Alves
    You need to define the monteExpr before the monteRun. The expressions are evaluated as the simulation runs, and so you can't add them afterwards.
