  3. Generate legenend on a plot
  • Replies 19
  • Subscribers 131
  • Views 27507
wgtkan
wgtkan over 13 years ago
I am using Virtuoso Design environment version IC6.1.5-64b.500.15 and I am trying to generate a parametric simulation with legends showing on the plot
I am able to carry out the parametric simulation but the legend is not showing. How do I produce the legend as shown on this diagram?
Thanks in advance.
Legened plot.pdf
  • wgtkan
     I have to save the code as abFixFonts.il in my working directory and write load('abFixFonts.i'") and abFixFonts() in my .cdsinit?
    Thanks in advance.
    Yes, or you can paste it into your CIW and type abFixFonts() in the CIW. Note that the load call that you wrote above should be load("abFixFonts.il")  (not single quotation marks).
  • wgtkan
    Hello Andrew:
    abFixFonts()
    That is what I have added in my .cdsinit file. I am getting a warning message that it is not a valid path. I see that my simulations are being saved at tmp directory to prevent from files overcrowding my alloted quota. WARNING* artSetWindowDataDir /spectre/schematic" is not a valid data directory. I do I change the waveform directory to save it into the tmp directory?
    Thank you again.
    You're getting a warning that what is not a valid path? Showing the precise details from the CIW or CDS.log really would help, as this warning can't be related to the code I sent.
    There's nothing in the code that can produce that artSetWindowDataDir warning. I think you probably need to show the entire info from the CIW around the warning - my guess is that you're showing part of the error message.
    If the simulation results are saved in /tmp, presumably something in your environment is setting the cdsenv for the projectDir.
    There should be no need to change the waveform dir to save it into the tmp dir.
  • wgtkan
     WARNING* artSetWindowDataDir: "/home/users/wako/simulation/Elema/BJT_IV_2/adexl/results/data/.tmpADEDir_wako/Elema:BJT_IV_2:1/simulation/BJT_IV_2/spectre/schematic" is not a valid data directory
    is the error I am getting in the cds.log file
  • wgtkan
    I have saved the code
    as abFixFonts.il in my in my
    root directory and wrote load("abFixFonts.il")
    abFixFonts()   in my .cdsinit file and here is the plot I am getting.
  • wgtkan
    The issue is fixed now. When I was saving the code, the text format was italics. That is why it was not working previously. I see the plot is different now.
    Thank you so much.
  • wgtkan
     Everytime I have to call the function from CIW using abFixFonts(). For some reason, everytime I start virtuoso and generate plot it wont come on by default.
    I can't see why that would be; I suspect that whatever file you are putting the call in is not being loaded. I would suggest contacting Customer Support.
