  3. Generate legenend on a plot
  • Replies 19
  • Subscribers 131
  • Views 27785
wgtkan
wgtkan over 13 years ago
I am using Virtuoso Design environment version IC6.1.5-64b.500.15 and I am trying to generate a parametric simulation with legends showing on the plot
I am able to carry out the parametric simulation but the legend is not showing. How do I produce the legend as shown on this diagram?
Thanks in advance.
Legened plot.pdf
    Graph->Properties->Graph Options, then alter the Legend Position. The right subwindow shows where I've set this to "above", the left subwindow shows the default which is "left".
  • wgtkan
     Thank you very much for your promt response Andrew.
    Best regards.
  • wgtkan
    Hello Andrew:
    These plots are very clean. Are these in png format and Helvetica font? I am using VIVA (virtuoso visualization and analysis) Version IC6.1.5-64b.500.15. I wanted to import my waveforms into word format for presentation.
    Regards and thanks in advance.
    It was actually a region screenshot with ksnapshot (not sure why I did that rather than File->Save Image, which if I use "Exact Copy of Window" should give me exactly what I get on the screen).
    I have a few problems with the fonts on my laptop - this is related to some font limitations in the Qt infrastructure we're using - so whilst the UI suggested that the plots you were seeing were using Helvetica, they weren't really (as you can see there are some serifs on the fonts).
    I normally use this bit of code to try fixing up my fonts - they actually set them to the default values:
    procedure(abFixFonts()
     let((curVal toolpartition pat)
        pat=pcreCompile("^Default")
        foreach(partition '(axis horizMarker referenceLineMarker vertMarker pointMarker
            refPointMarker specMarker interceptMarker circleMarker multiDeltaMarker
            transEdgeMarker graphLabel probe polarGrid smithGrid)
            sprintf(toolpartition "viva.%s" partition)
            when(envIsVal(toolpartition "font")
                curVal=envGetVal(toolpartition "font")
                printf("replacing %s font\n" toolpartition)
                envSetVal(toolpartition "font" 'string
                    pcreReplace(pat curVal "Helvetica" 1)
    Here's a resulting Save Image from having picked the above.
  • wgtkan
    Thank you very much indeed Andrew.
  • wgtkan
    I used the code to fix the formatting issues. I
    entered the code in the CIW and this is the plot I am getting:
    Best regards,
    Tuni
  • wgtkan
    I used the code to fix the formatting issues. I entered the code in the CIW and this is the plot I am getting:
    Best regards,
    Tuni
    Hi Tuni,
    After loading the code in the CIW, did you run the function abFixFonts() - I don't think so because your fonts still appear to have serifs.
    Kind Regards,
  • wgtkan
     Hello Andrew:
    AFter loading the code in the CIW, where do I run the function abFixFonts()? Do I have to load it in the CIW:
    Thanks.
    Just type abFixFonts() in the CIW (that's not "loading" it; it's executing the function). You could also do:
    load("abFixFonts.il")
    abFixFonts()
    in your .cdsinit so that it runs it each time you start Virtuoso (if it helps your problem). I'm assuming in the above you've saved the code into a file called abFixFonts.il
