  3. Trigger warning on sessioin start
  • Subscribers 133
  • Views 17165
wgtkan
wgtkan over 13 years ago
Every time I start, a cadence session, I see this warnings:
WARNING* (DEBASE-102068): No user triggers registered for viewType schematicSymbol.
*WARNING* (DEBASE-102068): No user triggers registered for viewType maskLayout.
*WARNING* (DEBASE-102068): No user triggers registered for viewType maskLayoutXL
I do not know where they are coming from. I looked them up in my .cdsinit or .cdsenv to settings.
I am using Version IC6.1.5-64b.500.15
Best regards,
    My guess is that somewhere in either your .cdsinit, or something loaded from your .cdsinit, you have these type of functions:
    deUnRegUserTriggers("schematicSymbol")
    If no user triggers are defined, it will give just that warning.
  • wgtkan
    I have looked in my .cdsinit and I do not see deUnRegUserTriggers("schematicSymbol")
    Thank you.
  • wgtkan
    This is all I see regarding Trigger functions in my .cdsinit
    The procAMS.cxt file registers Cadence trigger functions for all editors.
    ;;   This will place the banner, AMSutils, on each edit session
    ;;   A&MS trigger functions are
    ;;       schAMSTrigger          for schematic and symbol editors.
    ;;       leAMSTrigger           for layout and extract editors.
    ;;   If the A&MS trigger functions are unregistered by the customer site, the
    ;;   AMSutils banner may be placed by issuing the procedure placeAMSMenu().
    ;;   This function is bound to the PF11 key, or the "Stop" key on the SUN5
    ;;   keyboard.
    Thank you
    Well, it's almost certainly doing it somewhere in something loaded from the .cdsinit (maybe the procAMS.cxt context file mentioned above - hard to be sure). It could also be done in some SKILL loaded from a library's libInit.il. One way to test if it's in the cdsinit somewhere is to try:
    virtuoso -nocdsinit
    (or icfb -nocdsinit if it's IC5141, but I think you're using IC615).
    Then you'll have to narrow it down yourself in the .cdsinit. It may be in the IBM customization somewhere - I'm guessing - you may be calling one of their functions (such as "placeAMSMenu()" mentioned above) - perhaps somewhere there it is calling these functions.
    Maybe you should speak to IBM (assuming you narrow it down to being part of the PDK).
