  3. Schematic view settings in cdsenv
  • Subscribers 132
  • Views 17618
Abhilash B
Abhilash B over 13 years ago
Hi ,
I am using virtuoso 6.1.5 ,whenever I open schematic view dots are displayed in the background so if I want to change those then I have to do it manually by going in the Options->Display  so are there any commands for that so that i can save them in .cdsenv so that it will be permanent solutiion.
Abhilash
    Abhilash,
    Not quite sure what setting you're asking to control, but:
     schematic schGridType cyclic "none"
    might be what you want (it can be "none" "dotted" or "line").
    Or you might want:
     graphic dotStyleMajorGrid boolean t
    which causes the major grids to be dimmed.
  • skillUser
    skillUser over 13 years ago
     HI Abhilash,
    I think that you want the following setting in your .cdsenv:
    You can set the same thing interactively in SKILL using envSetVal or schSetEnv.
    Hope this helps!
    Lawrence.
  • theopaone
    theopaone over 13 years ago
    If you change the value in the interactive form, you should be able to save it to the .cdsenv, cellView or library from the form.
     Ted
