  3. Terminal Mismatch for MOS_a2d in virtuoso
  • Subscribers 133
  • Views 15117
Arslan
Arslan over 13 years ago
Hi, I am trying to run mixed signal simulations using ultrasim in Virtuoso 6.15. The test design is very simple and contains a vpulse (from analogLib) followed by MOS_a2d (from analogLib) which is followed by a buffer (written in verilog). when i try to simulate the design using ultrasim, following error occurs:
Error found by UltraSim during initializing the design.
    ERROR (USIMDB-11702): The UltraSim simulator detected a node mismatch error
        in the model 'a2d' in instance 'I3', in top level circuit.
        ( terminal mismatch 0 should be between [2,2] ).
instance I3 is MOS_a2d. how can this issue be resolved?
  • Quek
    Quek over 13 years ago
    Hi Arslan
    A similar issue was described in COS article 11633708, this issue has already been fixed IUS92-s015. Would you please try a higher version of IUS or INCISIVE package and let us know if it resolves the problem?
    Best regards
    Quek
    Also, I'm assuming you're using UltrasimVerilog rather than Ultrasim?
