  3. CDF Parameter Passing to the Netlist
  • Views 21030
gintel
gintel over 13 years ago
Here is my problem:
 I would like to create the hspiceD (or spectre, doesn't really matter) netlist for a circuit, let us call it depth0. This circuit has a subblock, i0, which is an instance of cell depth1. Inside depth1, there is a resistor and a capacitor. In addition, depth1 has a parameter called myParam (defaults to 1) that I would like to pass to the netlist. In other words, I would like to create a netlist like this:
.subckt depth1 in out
* INPUT:  in
* OUTPUT:  out
*.PININFO  in:I
*.PININFO  out:O
r0 in out 1e3
c0 out 0 1e-12
.ends depth1
.subckt depth0 in0 out0
* INPUT:  in0
* OUTPUT:  out0
*.PININFO  in0:I
*.PININFO  out0:O
xi0 in0 out0 depth1 myParam=1
.ends depth0
.end
To achieve this, I have edited the CDF parameters of depth1 (Scope:Cell, Layer:Base). I added a parameter called myParam, type:String, Default Value:1, Parse as CEL:yes, Parse as Number:yes, Store Default:yes. When I build the dept0 schematic and add the depth1 symbol, I can see the myParam parameter in the symbol view. In the Simulation Information of the CDF parameters window, in hspiceD simulator, I added myParam in instParameters section.
When I netlist, I do get the netlist above without the myParam value. In other words, the bold line above in the actual netlist is this:
 xi0 in0 out0 depth1
If in the stop view list, I put schematic, then I do get the bold line as I want, (i.e. xi0 in0 out0 depth1 myParam=1), but then the netlister does not descend into i0, and the netlist file does not include the depth1 subckt at all.
Is there a way to keep both the parameter value and the subckt information in the netlist?
Thanks.
    You need something in the schematic to actually use the parameter - e.g. set the resistor value to 1e3*pPar("myParam") - and then it should get netlisted.
  • gintel
    gintel over 12 years ago
     I am having the same issue with spectre. If I use the parameter inside the lower level schematic, parameter shows up in the netlist. However, I want this netlist to include the defined parameter even if I don't use itin the lower level schematic. Is there a workaround? Is there a dummy block I can add to include these in the netlist?
    As I said, the workaround is to use the parameter. You can always set something like:
    r=1k+0*pPar("YoureTheOneThatIWant")
    c=1p+0*pPar("IGotChillsTheyreMultiplying")
