  3. Persistent placement of Ruler pop-up window
  • Subscribers 132
  • Views 15147
aSand
aSand over 13 years ago
Does anyone out there have a solution to the following?:
While running CADENCE Virtuoso (version 6.1.5) within a GNOME environment and with
the 'Options Displayed When Commands Start' box checked within the User Preferences
pop-up window, the position of the Create Ruler pop-up window pops-up in the same screen
placement irregardless of  where it was last moved to. This is in contrast to all other pop-up
commands (Move, Stretch, etc.) which pop-up in a screen placement that they were last moved
to. Any help or hints would be much apprectiated! -Thanks!
    This is because the Create Ruler command recreates the option form each time, rather than re-using it. I don't really have a good argument as to why that is, so I suggest you log a case with customer support to file a CCR to get that changed.
  • aSand
    Excellent, Thank you!
     A report will be logged.
     Mark
