  3. Cadence waveform viewer display error
  • Subscribers 132
  • Views 17500
likelike
likelike over 13 years ago
 To whom it may help, we are using cadence virtuoso6.1.4 with science linux 6.
it was always fine with these combination in past year, until last week , there was an auto update for the secience linux 6,.
After update, the waveform viewer window always shows a automatic rotate. Furthermore, from CDS.log, we can find a libGL error, which is list below:
libGL error: failed to load driver: nouveau
libGL error: Try again with LIBGL_DEBUG=verbose for more details.
We have checked the packages
mesa-libGL, mesa-libGLU, libxp, glibc, libxt, libxi, libxrender, libxext, linxtst, gcc, ksh, xorg-x11-fonts, elfutils-libelF
all of them are updated to most recent version.
Can anyway tells us what else we can do to sovle this annoying issue.
 A whole CDS.log are attached in below as well.
Program: @(#)$CDS: virtuoso version 6.1.4 08/02/2010 02:27 (sjfdl083) $
Hierarchy: /home/esdcad/software/cadence/linux/ic614/tools.lnx86/dfII/
Sub version: sub-version IC6.1.4.500.6 (32-bit addresses)
Working Directory: xinyi0718.ecs.soton.ac.uk:/home/kl/design/IBM8RFradiofiber
COPYRIGHT © 1992-2009 CADENCE DESIGN SYSTEMS INC. ALL RIGHTS RESERVED.
© 1992-2009 UNIX SYSTEMS Laboratories INC.,
Reproduced with permission.
This Cadence Design Systems program and online documentation are
proprietary/confidential information and may be disclosed/used only
as authorized in a license agreement controlling such use and disclosure.
RESTRICTED RIGHTS NOTICE (SHORT FORM)
Use/reproduction/disclosure is subject to restriction
set forth at FAR 1252.227-19 or its equivalent.
Loading geView.cxt
Loading menuBuilder.cxt
Loading schView.cxt
Loading selectSv.cxt
Loading LVS.cxt
Loading layerProc.cxt
Loading xlUI.cxt
Loading auCore.cxt
Loading vhdl.cxt
Loading seismic.cxt
Loading ci.cxt
Loading ams.cxt
Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.06s.
END OF USER CUSTOMIZATION
IBM_PDK skill procedures for Cadence 6.1 - Jan 10 15:38:05 2011
Licensed Materials - Property of IBM - All Rights Reserved
Copyright: International Business Machines Corporation, 2013
This Material may not be copied without the written consent of
Semiconductor Research and Development Center, IBM Corp., Essex Junction, VT 05452-4299.
// Calibre Skill Interface * (v2008.4_37.26) *
// Copyright Mentor Graphics Corporation 2005
// All Rights Reserved.
// THIS WORK CONTAINS TRADE SECRET AND PROPRIETARY INFORMATION
// WHICH IS THE PROPERTY OF MENTOR GRAPHICS CORPORATION
// OR ITS LICENSORS AND IS SUBJECT TO LICENSE TERMS.
Loading awv.cxt
Loading rte.cxt
Initializing IBM_PDK functions
Default set for Left & Right WindowCoordIBM
System hardware set for Linux IBM_PDK procedures
Loading IBM PDK cmrf8sf Procedures
Setting calibre env variable table for cmrf8sf
Using menu definition file: /home/esdcad/designkits/ibm/ibm8rf/IBM_PDK/cmrf8sf/V1.8.0.4DM/cdslib/cmrf8sf/ibmPdkMenu.def
set cmrf8sf calibre env variables based on ibmPdkMenuCalibre settings
set cmrf8sf calibre env variables based on ibmPdkMenuCalibreDrc settings
set cmrf8sf calibre env variables based on ibmPdkMenuCalibreLvs settings
set cmrf8sf calibre env variables based on ibmPdkMenuCalibrePerc settings
cmrf8sf IBM_PDK menus set
Added CIW menu.
hiCloseWindow(window(2))
t
ddsOpenLibManager()
t
awvCreatePlotWindow()
window:3
Loading viva.cxt
Aborted
compose simulator input file...
...successful.
start simulator if needed...
...successful.
Loading paraplot.cxt
t
simulate...
INFO (ADE-3071): Simulation completed successfully.
reading simulation data...
...successful.
Loading hspiceD.cxt
Loading UltraSim.cxt
Loading AMSOSS.cxt
Loading AMS.cxt
sevOpenCalculator()
t
awvPlotSimpleExpression("v(\"/net013\" ?result \"dc-dc\")" ?plotStyle "Append" ?graphType "Rectangular" ?graphModifier "Magnitude")
t
java: ../../../src/mesa/swrast/s_renderbuffer.c:588: map_attachment: Assertion `srb->Map' failed.
Aborted
    I don't know what  you mean by "automatic rotate", but this shows the perils of using an unsupported Operating System.
    Anyway, the best would be to move to IC615 which is a supported version of the tools - and it's not using Java for the waveform tool (the problem you're seeing is a Java bug by the looks of things, related to Java's support of openGL, at a guess). "mesa" is a system for openGL emulation...
    If not, you could try doing this:
     setenv CDS_WAVESCAN_OPENGL "-Dsun.java2d.opengl=False"
    before starting virtuoso - this turns off OpenGL in Java when used from the waveform tool - there were some issues at times with how it behaved (not the problem you're seeing, but this might fix it too).
  • likelike
     Thanks, andrew!
    It does solve the problem! ^-^
