  3. Reopen MC results after closing adexl
  • Subscribers 132
  • Views 16240
Tobben24
Tobben24 over 13 years ago
I have runned a MC run using adexl, and got a nice overview of results, spec etc. Then I closed adexl, and when I reopened the adexl view the results tab was empty. Is it possible to me get this overview back in the results tab? All the files from the simulation was stored.
    In the "Data" assistant (where the tests are set up), there is a "History" tab. Click on that and you'll see previous history items. Go over the one you want, and then Right Mouse Button->View Results over the one you want. This will load it, and then it will open it in the right pane. You can switch to Yield, Detailed and so on as normal in the same way as you can when the simulation has just run.
  • Tobben24
    Perfect, just what I was looking for. Thanks:)
