  3. ADE XL Bug?
  • Subscribers 132
  • Views 15159
ADE XL Bug?
Tobben24
Tobben24 over 13 years ago
After running a MC run with signals with the same name between test benches I get a bug when trying to open/close(click on + or - icon on left side) summary. What happens is the when I want to close a signal summery(click on the minus icon), the summary collapse as we get a single line with information. However, the summary with the same name in another test is also affected. The minus icon here turns into a plus, which is not expected. When I then click on the plus icon, which is supposed to be a minus icon, it turns into a minus and the summary gets collapsed. So now we have a closed/collapsed summary with a minus icon. In addition, the first summary is reopened.
Virtuoso Design Enviroment version IC6.1.5-64b.500.14
    Please can you upload a screen shot of the relevant portion of the UI to clarify what you mean? (Use the Options tab when replying to the post).
  • Tobben24
    Added a screen capture where you can see I only have + icons, also on the summaries which are expanded.
    It's a bug - I've reproduced it. I'll file a CCR for this. Ideally if you can send me a private message on the forum with your work email address, I can associate it with you as a customer, which will help - then you can track it via Cadence Online Support.
    Kind Regards,
