  3. ADE XL Dynamic Spec
  • Replies 11
  • Views 21720
ADE XL Dynamic Spec
Tobben24
Tobben24 over 13 years ago
 Is it possible to create a spec for a test signal that is dynamic? Say you have a requirement to a signal that is based on what your supply is, ie. the output should be < Vdd*0.7.
I have been able to achieve this by creating a seperate test for each supply I have, and add numerical values in the Spec column in Outputs Setup. However, I feel that this is a workaround which is not optimal. My supply is set by a variable, so what I really want to do is add a list of supply values in the Design Variables in Corner Setup and have a Spec that is based on a this parameter.
  • StefanHi
    StefanHi over 11 years ago
    Thank you very much for your fast reply.
    Best regards, Stefan
