  3. How to change the Symbol @partName
  • Subscribers 132
  • Views 20590
RFStuff
RFStuff over 13 years ago
 Dear All,
Is there any way of changing  symbol partName ( displayed in while instantiating the object in symbol view in schematic editor).
I want this because:-
I copy a cellView A to a NewCell view B and make a change in the schematic and I preserve the Symbol view. But when I instantiate the cell B, the partName should be displayed B but instead it shows A. What I should do to make the partName displayed as B.
Kind Regards
    Several ways:
    1. When doing the copy make sure you have checked the "Update instances (of new copies only)" on the copy form. This will update the partName property on the symbol
    2. If you've already done the copy, do Edit->Properties->CellView in the symbol editor and change the value of the partName property
    3. Change the [@partName] label expression to be [@cellName] - then it will always reflect the cell name and not need an update to be done.
    4. Change the "TSG" template you're using when using create cellView from cellView to use @cellName instead of @partName - the template is at /export/home/apps/IC5141_isr/tools/dfII/samples/symbolGen (default.tsg) - take a copy of this and put it somewhere else and change the defLabel definition near the end to add [@cellName] instead of [@partName]. Then look in <ICinstDir>/tools/dfII/samples/local/schConfig.il and copy the definition of tsgTemplateMasters and put in your own .cdsinit and change the paths as needed - you can always add a new entry.
    5. If you want to alter which template master you use by default, you can do that with:
      schSetEnv("tsgTemplateType" "artist")
      (or use "digital", or "custom" or whatever you've called it). The "artist" template doesn't use @partName, so you might just want to use that.
