  3. ADEXL and VerilogA
  • Subscribers 129
  • Views 13946
ADEXL and VerilogA
Tobben24
Tobben24 over 12 years ago
Is it possible to control variables defined in a veriloga symbol from adexl as a normal parameter?
    If it's a parameter passed into the VerilogA model, I don't really understand what your issue is - that should just work?
    So maybe you'll need to elaborate?
  • Tobben24
     After some trying I found out that a parameter in VerilogA is overridable through the object property in schematic.
