  3. ADE XL multiple tests with different corners
  • Subscribers 132
  • Views 17506
Tobben24
Tobben24 over 13 years ago
Nevermind... I can that which tests that should be run can be selected when defining corners.
If you have multiple test in ADE XL, can you define which corners that should be runned individually for each test? Or does every test have to run the same corners. I know you can disable some tests and some corners to do want I want, but I want to be able to do this in a single run.
    Yes, you can do this on the corner setup form (see attached picture).
