  3. Library Generation
  • Subscribers 132
  • Views 14428
Library Generation
GreenGraphene
GreenGraphene over 13 years ago
Hallo,
I am creating a standard cell library. Should I generate Netlist including the load caps the schematic. if at all does it make any difference, including and ignoring load cas in Netlist used in Library generation.
    I would suggest you ask this question via customer support particularly if it's related to the Altos tools (your question is a bit non-specific).
    Kind Regards,
