  3. Color annotating schematic based on op region
  • Subscribers 132
  • Views 14723
boast
boast over 13 years ago
 So I currently have it set to use "Device checking" to identify regions, and then use highlight from the violations display for the schematic annotating. Is there a way to have this automated, so that the designer can just import a file, and when he runs the simulation everything will happen automatically?
 Thanks.
    Not entirely sure what you're doing, but you could put the corresponding spectre "assert" statements into a file, and then add this as one of your model files via the Model Libraries?
