  3. Virtuoso Layout view toolbars.
  • Subscribers 131
  • Views 16871
wgtkan
wgtkan over 13 years ago
How do I keep the quick access tool bars (file, edit, align and etc) in layout view, schematic view, and calculator not changing? Every time I run a new session some of the quick access tool bars do not show up.  Is there any command to keep them not from changing?
Thank you.
Version IC6.1.5-64b.500.15
  • skillUser
    skillUser over 13 years ago
    In the layout/schematic window use Window -> Workspaces -> Save As, and then use Window -> Workspaces -> Set Default and choose the name that you just saved to.  I don't know about the calculator.  Note that the workspace is specific to the tier of tool that you are using, and thus the default for VLS-XL is different to the workspace for VLS-L - so you may need to repeat the steps if using both tiers (same applies to VSE-L and VSE-XL) .
    Hopefully this answers your question?
    Lawrence.
