  3. how to set `ifdef switch`
  • Subscribers 132
  • Views 16533
Arslan
Arslan over 13 years ago
Hi, I have a standard cell library in .v format. It contains different set of modules each defined under `ifdef. How can I import a specific set using verilogIn.? where can I set the value used for `ifdef?
     Not sure if there's a better way (and I've not checked that even this will work), but one way could be to create a file, defines.v with:
    `define THIS that
    `define OTHER whatever
    i.e. `define the things you want found by the `ifdef. Then specify this file first in the list of Verilog files to import.
    I'd be interested to know if it works (I don't have time to try it myself).
  • Arslan
     Thanks Andrew, it works.
    -Arslan
