  3. Adjusting ADE window Size in IC5141
  • Subscribers 133
  • Views 15400
RFStuff
RFStuff over 13 years ago
 Dear All,
I am using IC5141. The ADE window has a fixed size. So even if you enalrge it, the Design, Design Variables, Analysis and Outputs sub-windows don't get enalrged.
Is there a way to enalrge it as I wish.
Kind Regards,
  • Kabal
    Kabal over 13 years ago
     IC5141 is what Dinosaurs used.
    In IC615 ADE window can be enlarged together with its other sub-windows.
  • RFStuff
     Kabal,
    That I know. But your reply is of no help to me !!!
    It may be no help to you, but that's the way it is. I was going to reply the same (Without the comments about dinosaurs)!
  • RFStuff
     Well,
    Actually I was scared of the fact that IC5141 is made for  dinosaurs.
    I can't imagine how big it is.
    By the way, Andrew:-
    Could you please  have a look at my query post:-  http://www.cadence.com/community/forums/T/25743.asp. Nobody so far has replied.
    May be it is really trivial. But I am not able to achieve that yet. It will be really helpful at this point if you could reply to it.
