  3. How to change line styale in Wave scan wave form
  • Subscribers 128
  • Views 16095
wgtkan
wgtkan over 12 years ago
How do I change the default line type in the wave scan waverfom.  I am using Viva wave form Graph XL version IC6.1.5-64b.500.15. Every time I generate a plot the lines are dotted and I have to go to edit and properties to change the line style/type line to solid.
Is there any way to produce these by default?
Thanks in advance
    Your message is a bit confusing because you're talking about wavescan (which was the waveform tool in IC5141) and ViVA (the waveform tool in IC615). Anyway, the most likely problem is that the definition of the packets used in the display.drf for the y0 to y9 drawing layers. In some PDKs these are defined to be dotted/dashed lines. ADE uses these layers to probe any outputs plotted on the schematic so that the nets are highlighted with the same colour/style as they are plotted in the waveform window. So it's ADE doing this.
    The packets will be defined in the display.drf - probably  coming from your PDK. So you may need to change the definitions in the PDK's display.drf (the technology file will define what packet name is used for each layer purpose).
  • wgtkan
     Sorry for the confusion. I meant Viva because I use IC615. I went ahead and edited the disply.drf by going to the CIW > display resource manager > edit and changed the layers styles for y0 -yo to solid but still when I plot on the schematic, I see dotted lines. Is there any skill command to fix this issue.
    My guess is that you changed the wrong packets - I just tried this and it worked fine (I did it interactively). I could see the line styles on the nodes highlighted in the schematic change, and once I replotted the waveforms they also were correct (you have to replot to see the change),
    Anyway, this code might help. Make your schematic window the current window, and then call this function. It finds the packet names for the y0-y9 drawing layers in the technology associated with your schematic window, and then alters those packets.
    /* abSetY09LineStyle.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Feb 03, 2005
    Modified   A.D.Beckett
    By         Apr 08, 2013
    Function for setting the line style on the y0 to y9
    layers conveniently.
    Modified to allow the packet names to be obtained from
    the tech file, as some technologies use non-standard packet names
    for y0 to y9
    SCCS Info: @(#) abSetY09LineStyle.il 04/08/13.07:05:49 1.2
    *     abSetY09LineStyle([?lineStyle "solid"] [?cvId cvId])     *
    *         Sets the line style of the y0 to y9 layers.          *
    *      For example, use with "thickLine" as the argument       *
    *       to set the lines to be thick, or "solid" (or no        *
    *              argument) to make them thin again.              *
    procedure(abSetY09LineStyle(@key (lineStyle "solid") (cvId geGetEditCellView()))
        let((display packet tfId LP packetName)
            tfId=techGetTechFile(cvId)
            unless(tfId error("Could not obtain tech file for cellView %L\n" cvId))
            display=drGetDisplay("display")
            ; Check that the specified line style exists
            unless(drGetLineStyle(display lineStyle)
                error("%s is not a valid line style" lineStyle)
            ) ; unless
            ; Iterate through y0 to y9
            for(layerNum 0 9
                LP=techGetLP(tfId list(sprintf(nil "y%d" layerNum) "drawing"))
                when(LP
                    packetName=techGetLPPacketName(LP)
                    ; Ensure the packet exists
                    unless(
                        member(packetName drGetPacketList(display))
                        error(sprintf(nil "%s is not a valid packet" packetName))
                    ) ; unless
                    ; Get current packet and update
                    packet=drFindPacket(display packetName)
                    drSetPacket(display nth(1 packet) nth(2 packet)
                        lineStyle nth(4 packet) nth(5 packet))
            ) ; for
            hiRedraw()
            t
        ) ; let
    ) ; procedure
