  3. Printing operating point values to file
  • Replies 8
  • Subscribers 133
  • Views 19671
anirbanbob
anirbanbob over 13 years ago
 Hi
 I am a new to ocean scripting and currently I am trying to print operating point parameters(gm,rds,etc) to a file through ocean.The simulation runs fine. I don't want to use ocnprint because it introduces column headers. I want to use frpintf instead. I tried something like:
 gm = OP("/M0","gm")
fprintf( out "%5.2" gm)
 -> this prints  srrWave:0x1f7c0060 instead of the deciaml value. What is the correct way to do this?
 Cheers
Anirban
  • berndfi
    berndfi over 13 years ago
     This is not ocean what you have posted.
    Try this:
    openResults( "<yourResultsPsfDir>")
    selectResults( 'dcOpInfo )
    report( ?output "<yourOutputFile>" ?name "/M0" ?param "gm" )
    And have a look at the "OCEAN Reference" manual.
  • berndfi
    For rthe initial question, OP usualy should return a float.
    You may test it with "type(gm)", where gm is the varialbe which holds the gm value.
    For the print I would suggest a " fprintf( out "%e" gm )".
    Your post doesnt have a vaild format spec for fprintf, don't know if this is a typo.
    Should be OK using OP, but my guess is that you've done a parametric sweep or something like that? Could that be the case?
  • anirbanbob
    Hi Berndfi ...  Thanks for your reply. Will try them
    Hi Andrew.. Thanks for your reply. I am not running parametric sweep. I have a DC-biased NMOS and have simply run a simulation with save DC OP set.What could be wrong?
    Can you post your whole OCEAN script?
  • anirbanbob
     Here it is:
     ;====================== Set to XL mode =========================================
    ocnSetXLMode()
    ocnxlProjectDir( "**************" )
    ocnxlTargetCellView( "QA" "NMOS" "adexl_anirban" )
    ocnxlResultsLocation( "" )
    ocnxlSimResultsLocation( "*******************" )
    ;====================== Tests setup ============================================
    ;---------- Test "QA:NMOS:1" -------------
    ocnxlBeginTest("QA:NMOS:1")
    simulator( 'spectre )
    design( "QA" "NMOS" "schematic")
    modelFile(
        '("$PDKROOT/models/spectre/MOS.scs" "typ")
        '("$PDKROOT/models/spectre/RES.scs" "typ")
        '("$PDKROOT/models/spectre/CAP.scs" "typ")
        '("$PDKROOT/models/spectre/DIO.scs" "typ")
    analysis('dc ?saveOppoint t  )
    envOption(
        'analysisOrder  list("dc")
    temp( 27 )
    gm = OP("/M0","gm")
    ocnxlOutputExpr( "(OP(\"/M0\" \"vds\") / OP(\"/M0\" \"ids\"))" ?plot t)
    ocnxlOutputExpr( "OP(\"/M0\" \"ids\")" ?plot t)
    ocnxlOutputExpr( "OP(\"/M0\" \"gm\")" ?plot t)
    ocnxlOutputExpr( "OP(\"/M0\" \"vth\")" ?plot t)
    ocnxlEndTest() ; "QA:NMOS:1"
    ;====================== Sweeps setup ===========================================
    ;====================== Model Group setup ==========================================
    ;====================== Corners setup ==========================================
    ocnxlCorner( "C0"
          ("model" "$PDKROOT/models/spectre/CAP.scs" ?section "\"typ\"")
          ("model" "$PDKROOT/models/spectre/DIO.scs" ?section "\"typ\"")
          ("model" "$PDKROOT/models/spectre/MOS.scs" ?section "\"typ\"")
          ("model" "$PDKROOT/models_old/spectre/MOS.scs" ?enabled nil  ?section "")
          ("model" "$PDKROOT/models/spectre/RES.scs" ?section "\"typ\"")
          ("modelGroup" "")
    ocnxlCorner( "C1"
          ("model" "$PDKROOT/models/spectre/MOS.scs" ?enabled nil  ?section "")
          ("model" "$PDKROOT/models_old/spectre/MOS.scs" ?section "\"typ\"")
          ("modelGroup" "")
    ;====================== Test v/s corners setup =================================
    ;====================== Job setup ==============================================
    ocnxlJobSetup( '(
        "blockemail" "1"
        "configuretimeout" "300"
        "distributionmethod" "LBS"
        "jobqueue" "cadence.q"
        "lingertimeout" "300"
        "maxjobs" "8"
        "name" "******************"
        "preemptivestart" "1"
        "reconfigureimmediately" "1"
        "runtimeout" "-1"
        "showerrorwhenretrying" "1"
        "showoutputlogerror" "1"
        "startmaxjobsimmed" "1"
        "starttimeout" "300"
    ;====================== Disabled items =========================================
    ;====================== Starting Point Info ======================================
    out = outfile("./results.txt" "w")
    ;====================== Run command ============================================
    ocnxlRun( ?mode 'sweepsAndCorners ?nominalCornerEnabled nil ?allCornersEnabled t ?allSweepsEnabled t)
    fprintf(out "%5.2f" gm)
    ;====================== End XL Mode command ===================================
    ocnxlEndXLMode()
  • anirbanbob
     Hi Andrew, were you able to spot any error in the file? type(gm) returns other, how do i get the float value?
     Sorry, meant to reply at the time but was busy travelling.
    I'm slightly surprised it works at all, as the gm variable is set during the definition of the test, not when it is run. But assuming that magically works somehow, you are running over corners, so you will have a waveform with the gm versus corners.
    I would suggest you try doing something like:
    selectResult('dcOp)
    sweepNames()
    at the end to see what the sweep names are - you will probably have to do a value(gm ...) to find the value at the value of one of the sweep variables to "slice" the data.
    Or define the gm measurement as an output expression for the test?
    Apologies for the quick (and untested) reply - I'm rather busy today.
