  3. Average power calculation
  • Subscribers 133
  • Views 33304
sagar2012
sagar2012 over 13 years ago
Respected Sir/Madam
 i have designe the 16 bit adder (ripple carry adder ) using virtuoso (schematic) .
and simulated please anyone know how to calculate the average power,static,dynamic power calculation.
i am a student.
  • sagar2012
    Respected Sir/Madam
    i am a student.
  • Gangadhar Redd
    Gangadhar Redd over 13 years ago
     Hi Sagar,
    While simulating 16 bit RCA in virtuos Analog Design environment window select OUTPUT ..> saveall.
    In save all options enable all options.
    Run simulation.
    In waveform window select Browser..> results...> open results    , then Select Waveform Data base window will open ,here select psf file. In left side of waveform window we can observe a browser. In browser doble click on tran option
    Here we can have current , voltage and power signals at various parts of the design.
    Double click on pwr option. Then we can observe wave of power signal in waveform window.
    select pwr signal and do as follows to get avg power
    In Waveform window goto TOOL option open calculator.
    In calculator go for Functional panel select average function  and then clik on evaluate button.
    The obtained value is the average value.
