  3. automatically run a routine when run button is choose
  • Replies 11
  • Views 21381
NcfC
NcfC over 13 years ago
Hi all.
I'm using ic5141 and I would like to automatically run a routine everytime I choose to run a simulation, either by pressing Simulation->Run or by pressing the "Netlist and Run"/"Run" icons.
 I tried to follow the post on "automatically run a routine when a menu item is invoked from CIW or schematic window" - www.cadence.com/.../25992.aspx but it didn't work.
 Cold someone have any idea on how to proceed?
 Thanks in advance.
  • NcfC
    Andrew,
     you were right. There was an error message in the CIW about some other customization and the .cdsinit did not get loaded. But I didn't see it.
    After removing the error and .cdsinit correctly loaded, everything ran smoothly, as you predicted. Thanks very much.
    Regards
