  3. [SOLVED]: IC615 installation?
  • Replies 13
  • Subscribers 136
  • Views 24598
emax
emax over 13 years ago
Previously the installation package was based on CDROMs and we normally point to CDROM1 in the InstallScape to start installation. But for the one I downloaded have not found any CDROM folder.
The list of folders and files in the download are:
1. iscape_logs (folder)
2. kits (folder containing lots of t.Z files)
3. .kpsource (file)
4. Hotfix_IC06.15.xxx-615_lnx86.sdp (file)
and
5. ic_index.sdx (file)
The MMSIM12 also has similar files and folders. The installation procedure changed or am I missing something? Where is the base package?
    I tried to be smart then and format it nearly - but it got slightly messed up. Anyway, hopefully you can see that CDROM1/SETUP.SH is under the directory for each of the tarballs.
  • hari1980
    hari1980 over 12 years ago
    hello andrew when i run setup.sh it just vanishes
    "It just vanishes". What does that mean? I have no idea what you're telling me or what can "vanish" when you do this. Please describe more clearly precisely what you've done and precisely what happens, and ideally in a new thread as mentioned in the forum guidelines.
