  3. analog_extracted simulation
  • Subscribers 132
  • Views 14589
Magistus
Magistus over 13 years ago
hi,
first: sorry for my bad english!
i want to simulate my design by using the "analog_extracted"-layout. in the "environment options"-window i wrote "analog_extracted" at the beginning of the "switch view list"-line. if i use ADE L, then the simulation runs without any problems. but if i use ADE XL i get the message, that new variables were found {extraction, in, not, used} and i have to assign values to these variables before running simulations. i don't know where these variables come from.
what i am doing wrong?
thank you!
    There may be something wrong in the CDF setup for some device - it suggests to me that something is being netlisted as "not used in extraction" - but it's hard to know without seeing the data.
    I suggest you contact customer support (hopefully you have by now). Alternatively, looking at the netlist you got in ADE XL might help (use Right Mouse->View Netlist over the failing point).
