  3. LVS check with cds_thru
  • Subscribers 131
  • Views 6403
StreamCX
StreamCX over 13 years ago
I connect Global and pin in schematic via cds_thru in schematic.  Is this connection normal for LVS?
Then another man try to do lvs but error appears. "dumping stack". Is there some connection?
    It depends on which Physical Verification tool you're using. You didn't say the tool, the version, or really give much to go on. Many people are able to use cds_thru successfully for such tasks, so presumably whatever issue you have is related to the tool/version/setup that you're using - and that's information that you unfortunately didn't provide, which probably contributed to the lack of response from anyone in the forum.
