  3. Regarding stability sims (STB) --> Over corners STB phase...
  • Subscribers 132
  • Views 2044
Regarding stability sims (STB) --> Over corners STB phase plots shows reversal
kasj
kasj over 13 years ago
Hi ,
 There is one problem which I am facing while running STB(stability) over corners for an op-amp in closed loop. Sometimes my Phase plot starts from 180 deg and sometimes it starts from 0 deg. I have no clue why is that happening ?
Although I have tried trasnsients it doenst show any thing strange and system seems to be quite stable.
Thanks in advance !
    I know a colleague is dealing with a similar reported issue, and R&D are looking into it. I suggest you contact customer support and then we can take a look at your example to find out why and see if it highlights an issue that needs fixing.
    Kind Regards,
  • kasj
    Thanks Andrew for a quick reply.
    I will mail my problem in customer support tab as you mentioned.
