  3. OCEAN write generic procedure to plot waveforms
  • Subscribers 132
  • Views 17659
The Setlaz
The Setlaz over 13 years ago
I'm trying to write a generic procedure to plot waveform that takes the plot macro parameters as procedure input arguments.
Basically, I want something like this :
procedure( my_procedure(  signal signal_name strip ...stuff... )
    plot( sprintf( "%s ?expr '("%s") ?strip "%d" " signal signal_name strip ) )
    ...stuff...
    hardCopy...stuff
);procedure
It seems like I cannot plot something out of a sprintf because sprintf does not return an object, right ?
Is there any way to get that working ?
Damien
    Well, sprintf returns a string, so you can't just pass that to plot. In general trying to do run-time evaluation of a macro like plot is going to be problematic, so I'd suggest that  you do:
    procedure(my_procedure(signal signal_name strip)
      awvPlotWaveform(currentWindow() || newWindow() list(signal) ?expr list(signal_name) ?stripNumber list(strip))
      ; hardCopy stuff
    So use the underlying function.
  • The Setlaz
    Thanks you very much for your answer. It seems to be working !
    Do you have any documentation on the awvPlotWaveform function ? I can't find anything in the manual.
    What is the difference with the Plot function ?
    Damien
    It's documented. In IC615 it's in <ICinstDir>/doc/vivaxlskill/vivaxlskill.pdf (and cdnshelp would find it). In IC5141 it's in <ICinstDir>/doc/skartistref/skartistref.pdf (I searched in cdsdoc, and found it).
    The plot() function has some convient options - it will create a window if one doesn't exist already, and you can just do plot(sig1 sig2 sig3) for example - the awvPlotWaveform() is a bit more verbose.
  • The Setlaz
    Alright. Does it mean that the plot() macro is kind of wrapper for awvPlotWaveform() function ?
    I will look at the documentation tomorrow - I only looked at OCEAN Refence and SKILL Language Reference and SKILL User's Guide maual. Thanks a lot for your help.
    Damien
    Effectively, yes. It's actually a wrapper around either awvSimplePlotWaveform or awvPlotExpression - which are all very similar to awvPlotWaveform.
  • The Setlaz
    Thanks for the details !
    I have another question regarding the plot. I would like to change the defaults size of the graph being saved.
    I tried creating a window using the syntax you gave a few times :
    awvCreatePlotWindow(?bBox list(100:100 1000:600))
    But when I open the plot image, it is still a 800 x 600 graph.
    I also tweaked my .cdsenv to make Viva to plot to large window using the following settings :
    viva.graphFrame width string "1920"
    viva.graphFrame height string "1152"
    It works, when I run OCEAN without the -nograph option, the graph is plotted to a big OCEAN window, but it still saved to a 800 x 600px.
     I'm running Cadence 6.1.5.162
    Damien
