  3. streamOutKeys error with IC6.1.5 ?
  • Subscribers 132
  • Views 15432
isazulkc
isazulkc over 13 years ago
 I am trying Cadence IC6.1.5 and it seems to have some problem with the streamOutKeys syntax. Is there a new streamOutKeys syntax for IC6.1.5?
I have a template.layout file (see below) to directly fill the calibre layout export setup. This template.layout file is the one I used for Cadence IC5.1.4  and it works fine. but with Cadence IC6.1.5 when loading the template file I got this error:
*WARNING* (reader): a '(' at line 1 was still unclosed on EOF, ')' added at line 1 of string "streamOutKeys = list(nil"
*Error* symbolToString: argument #1 should be a symbol (type template = "s") - (streamOutKeys = list(nil)).
In both case I used the same version of Calibre v2012.2_17.11, so I don't the the version of calibre is the problem.
Do you have any idea about this problem ?
Kc.
TEMPLATE.LAYOUT File
'runDir "./LVS"
'libName ""
'primaryCell ""
'viewName "layout"
'outFile "."
'scale 0.001000
'units "micron"
'hierDepth 32
'convertToGeo ""
'maxVertices 200
'refLib nil
'libVersion "5.0"
'checkPolygon nil
'snapToGrid nil
'simMosaicToArray nil
'caseSensitivity "preserve"
'lineToZeroPath "path"
'convertDot "ignore"
'rectToBox nil
'convertPathToPoly nil
'useParentXYforText nil
'reportPrecision nil
'runQuiet nil
'errFile ""
'NOUnmappingLayerWarning nil
'techFileChoice nil
'pcellSuffix "DbId"
'respectGDSIILimits nil
'cellMapTable ""
'layerMap "../tsmc18.layermap"
'textFontTable ""
'convertPin "text"
'pinInfo 1
'propMapTable ""
'propSeparator ","
'userSkillFile ""
'rodDir ""
    The stream interface is completely different in IC61, and the template file has changed. There is support for setting the streamOutKeys variable in SKILL, but if it's a template file, the best thing is to translate it using the pipo2Xstrm.pl utility:
    pipo2Xstrm.pl -in oldTemplate -out newTemplate
    Where oldTemplate is your old format filename and newTemplate is the one you want to generate.
  • isazulkc
    Thanks, it works now :). I just had to change "#" by ";" for the comments cause "#" was considered as an illegal character when not at the beginning of a line.
    Best Regards,
    Kc.
